Error message
- Notice: Trying to access array offset on value of type int in element_children() (line 6301 of /data08/c7232408/public_html/includes/common.inc).
- Deprecated function: implode(): Passing glue string after array is deprecated. Swap the parameters in drupal_get_feeds() (line 385 of /data08/c7232408/public_html/includes/common.inc).
- Deprecated function: The each() function is deprecated. This message will be suppressed on further calls in menu_set_active_trail() (line 2375 of /data08/c7232408/public_html/includes/menu.inc).
Autospeed Cellulose Primer Filler Grey
Autospeed Cellulose Primer Filler produces the ideal surface for the application of cellulose or two pack acrylic enamels in both air-dry and low bake systems. It can be used as a primer on steel or as a filler coat on properly prepared primed surfaces. It easy to apply and flat, and has a high build.
Technical Data
Product Code:
CP0505
VOC Content:
g/L
This product is suitable for industrial use only.
Downloads:
01260 290 666
ChurchillPaints on LinkedIn
twitter.com/ChurchillPaints
facebook.com/ChurchillPaints
